Ok, trailer lights for real
Old 05-25-2024 | 05:59 PM
Columbiar's Avatar
Default Ok, trailer lights for real
So I fixed the bad wires and replaced the plug. Still nothing. Dash doesn’t recognize a trailer. Trailer lights are good because they work with other vehicles. Still getting B1C57-14 (2F) among some other odd codes with a slight lag in starting the truck. None of this was happening prior to initially plugging in the lights. Thoughts?
Old 05-26-2024 | 03:46 AM
loanrangie's Avatar
LED or filament bulbs ?
Old 05-26-2024 | 09:58 PM
Columbiar's Avatar
Both. Tail lights are LED and side lights are filament
Old 05-26-2024 | 10:41 PM
loanrangie's Avatar
Then you need resistors so the car detects a trailer and stops the rapid blinking and relays to stop the pulsing..
Apothe (05-27-2024)
Old 05-28-2024 | 07:50 PM
Columbiar's Avatar
Sorry, not sure what you mean. Nothing is happening. The lights work fine when I hook up my ford pickup.
Could this error code have something to do with it?B1C57-14 (2F) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
Old 05-28-2024 | 10:06 PM
loanrangie's Avatar
Code is not related to your trailer, trailer wont be detected due to the LED's so needs resistor to put a load on that can be detected. The LED's will flash fast and oddly due to the vehicle sending pulses down the circuit looking for a trailer.
Old 05-29-2024 | 11:42 AM
Columbiar's Avatar
Thank you. But there are no lights at all, fast blinking or not. Does this still indicate a resister is needed? And how would I go about installing a resister?
tks
Old 05-29-2024 | 05:15 PM
loanrangie's Avatar
tks
Yes you will need them but first you need to work out why they aren't working, most likely a wiring issue on the car since the trailer lights work on another vehicle.
Old 06-01-2024 | 07:40 AM
Rufflyer's Avatar
Have you confirmed that there is power at the plug on the car? I don't recall the pinout right now, but on the 4 pin ground should be different that the other 3. From there you can turn on the 4 way flashers and check for power for brake / turn signal and turn on headlights for the marker lights.
Hope this helps
Jeff
Old 06-01-2024 | 12:34 PM
Columbiar's Avatar
Tks. I’ll take a look at that.
Quick Reply: Ok, trailer lights for real
