PCV noise or valve cover leak? (video)
Hi guys,
First time post here! I had a hissing sound from the passenger side of the motor so I went ahead and replaced the PCV valve as a precaution. After replacing the valve, the hissing noise is still there. I'm wondering if this is simply the normal noise of the PCV valve or does is sound like I have a leak from my valve cover gasket/sparkplug tube gasket? https://photos.app.goo.gl/h1o4EJbtBsTSkJt19 |
Could it be an exhaust leak? Maybe look for a hole in the manifold...
I had a noise like this for a long time, never got it to go away.
>replaced PCV >replaced PCV to intake hose >checked intake hoses for any leaks If it hasn't caused a CEL it won't be a huge issue for now. |
Originally Posted by houm_wa
(Post 678611)
Mine has the same hissing noise, figured it was the PCV doing its thing.
Originally Posted by djkronik57
(Post 679633)
Originally Posted by junya
(Post 679699)
That's good to hear, thanks!
Sounds pretty normal to me. In fact I was working on a friends LR3 tonight and it has the same sound. At first I though it was a leak in the AC lines, we were charging it up. Just the PCV, they can be rather loud like that. I think its at times louder than other times because of the EGR being open or not - maybe, thats just a guess. The 4.4 really, really hates vacuum leaks. Open the oil fill cover or even the oil dip stick and the engine can faulter. So if it was a really intake leak it would be running horribly. But the engine sounds healthy.
Originally Posted by Olivier Languedoc
(Post 734774)
I have that same sound. Trying to figure it out also. I ordered a new PCV before finding this post. Since last year anything changed with the noise?
