PCV noise or valve cover leak? (video)
Old Jan 31, 2019 | 11:37 AM
junya's Avatar
Default PCV noise or valve cover leak? (video)
Hi guys,
First time post here! I had a hissing sound from the passenger side of the motor so I went ahead and replaced the PCV valve as a precaution. After replacing the valve, the hissing noise is still there. I'm wondering if this is simply the normal noise of the PCV valve or does is sound like I have a leak from my valve cover gasket/sparkplug tube gasket?
https://photos.app.goo.gl/h1o4EJbtBsTSkJt19
Old Jan 31, 2019 | 12:18 PM
houm_wa's Avatar
Could it be an exhaust leak? Maybe look for a hole in the manifold...
Old Jan 31, 2019 | 03:19 PM
DavC's Avatar
I had a noise like this for a long time, never got it to go away.
>replaced PCV
>replaced PCV to intake hose
>checked intake hoses for any leaks
If it hasn't caused a CEL it won't be a huge issue for now.
Old Feb 1, 2019 | 07:07 AM
junya's Avatar
So you think this isn't a normal sound for the 4.4L?
Old Feb 7, 2019 | 06:25 PM
djkronik57's Avatar
Mine has the same hissing noise, figured it was the PCV doing its thing.
Old Feb 8, 2019 | 09:22 AM
junya's Avatar
That's good to hear, thanks!
Old Jun 30, 2020 | 12:51 PM
Olivier Languedoc's Avatar
I have that same sound. Trying to figure it out also. I ordered a new PCV before finding this post. Since last year anything changed with the noise?
Old Jun 30, 2020 | 07:51 PM
DakotaTravler's Avatar
Sounds pretty normal to me. In fact I was working on a friends LR3 tonight and it has the same sound. At first I though it was a leak in the AC lines, we were charging it up. Just the PCV, they can be rather loud like that. I think its at times louder than other times because of the EGR being open or not - maybe, thats just a guess. The 4.4 really, really hates vacuum leaks. Open the oil fill cover or even the oil dip stick and the engine can faulter. So if it was a really intake leak it would be running horribly. But the engine sounds healthy.
Old Jul 1, 2020 | 05:33 AM
junya's Avatar
noise hasn’t changed since last year. No cels or other issues either. I chalked this sound up as normal.
DakotaTravler
Apr 11, 2019 09:28 PM
michael1272
Oct 18, 2012 07:33 PM
sloan74
May 12, 2011 10:11 PM
hollis
Sep 14, 2008 08:27 AM
Spike555
Oct 6, 2007 08:56 PM
