programming keys
Old Sep 12, 2006 | 01:24 AM
LR3PO's Avatar
5th Gear
Default programming keys
just want to know if anyone here was successful in reprogramming their keys to make suspension go up or down. I wanted to avoid going to the dealership if possible.
Thanks
Old Sep 12, 2006 | 01:37 AM
HerbD's Avatar
8th Gear
Default RE: programming keys
Good question. I looked into doing this (lowering vehicle from outside using key fob) since one of the family members has a difficult time getting into the LR3 at normal heighth. I had anticipated being able to lower the LR3 as we approached the parked vehicle. After trying several times following the owner's manual, I couldn't get it to work.
Asked the service rep, who has been great on all other matters, and it sounds like it can be done when the safety flashers are blinking. I suppose it is a safety matter similar to the doors having to be closed before going up or down. I opted not to do it if the vehicle had to look like a landing spaceship. Now I run ahead, start the car, with doors closed, and then get back out and help the passenger get in.
Any one else have a better experience?
Old Oct 27, 2006 | 04:34 PM
LR3inCanada's Avatar
8th Gear
As I understand it, the automatic lowering thing has to be done with the engine running to power the air compressors... It didn't make much sense to me, as how would I hit the remote button with the engine running?
If someone can better explain this?
Thanks!
Old Dec 15, 2006 | 03:31 PM
o5lr3hse_06RRShse's Avatar
These are the steps that I took on my 05 LR3 HSE and 06 Range Rover Sport HSE
I'll start from the beginning.
To Program your Key to use the key to remote control the Suspension:
1) Turn on Vehicle with engine running
2) Turn off Vehicle
3) Quickly turn on Hazard flashing lights (#3 and 4 has to be done within 60 sec after turning off vehicle)
4) On Your Key while with the hazard lights are still flashing and doors closed: On your key Press and hold down the button with the Land Rover logo then Press down on suspension ****. You'll hear a bing sound confirming that it was programmed.
To Remote Control your suspension:
1) Vehicle has to be turned off
2) Turn on Flashing Hazard Lights (2-5 can be done at any time with vehicle off and all doors closed)
3) Exit the car and make sure all doors are closed
4) On your key, PRESS and HOLD down the Land Rover Logo Button.
5) While still pressing down on the Land Rover Logo Button, press the unlock button to lower and lock to raise the vehicle.
I hope this will help you and the others as I also had a difficult time programming my key.
Any question, you can email me at secret_cha@yahoo.com.
Old Jan 18, 2007 | 09:57 PM
MINIrover's Avatar
4th Gear
Programming your key to do the suspension is pretty useless. You still need to enter your car, turn on the blinkers, close the doors, before you can lower/raise the suspension while pressing key's button. The only advantage is that you don't have to start your engine.
It would have been useful if you can do the function without having to turn on the blinkers, but I guess Rover did this for safety reasons.
I, therefore, went with the auto lights which is useful when parked in dark places.
Old Feb 6, 2021 | 12:20 PM
mawRover's Avatar
Does anyone know if you can use the IIDTool or something similar to disable the need to use the hazards lights to raise and lower from the key fob? I agree with the above poster, it's basically a useless function if you have to enter the car.
Huttonville Hauler
Feb 25, 2024 03:59 PM
hellohelloo4
Dec 17, 2013 02:53 AM
leddifer
Feb 19, 2010 08:32 AM
richierichrover
May 27, 2009 09:42 PM
certifiedimports
Aug 30, 2007 12:02 PM
