-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   the relash module for coil springs (https://landroverforums.com/forum/lr3-28/relash-module-coil-springs-120379/)
rob bartleman Jan 23, 2024 02:10 PM
hello friends...
January, 2023! Are there new options for dealing with the suspension module after doing a coil spring changeover on a 2006 LR3? The Three that I bought already had the coils done on it, but without an accompanying module. I know Atlantic British carries the module (and harness kit), and that Dunlop (UK) is a manufacturer of that kit. Are there other less expensive options at the moment?
And I should ask if that "chime" has a way of being neutralized?? (I could almost live with the lack of special options... but the chime might drive me around the bend!)
glad for your replies!
Sorry... title should read "the Reflash module for coil springs"
loanrangie Jan 24, 2024 12:32 AM
There are no other options for that module and even then they are hard to find for a reasonable price. I would have thought that disabling EAS in the CCF would have the same affect but obviously not since there are modules required for this.
rob bartleman Jan 24, 2024 09:14 AM
I expect you are right, Loanrangie. I mean to continue my search for a reflash module that costs less than a full set of tires usually cost. My current technical obstacle is that the truck needs to be inspected for safety before I can register the truck. In Manitoba that means there can be no "lights on the dash," not even trivial ones like the brake pad sensors, or TPMS. So the Three Amigos has to be dealt with. If someone knows of a way to deal with the "chime", I would be glad to disable it!
DakotaTravler Jan 25, 2024 04:37 PM
I still do not understand how there is not some config in the CCF that would resolve this versus needing a module. I mean I would think unplugging the EAS module and editing the CCF would be enough based on how so much more can be edited without issue.
rob bartleman Jan 25, 2024 05:07 PM
That sounds true to me, DT. I have held off ordering the Blackbox Solutions scanner, but having to resolve this issue tips the scales. (When the one supplier I have located so far wants USD 600 for their kit, the $900 or so price for the BBS scanner becomes a bargain. CCF editing is uncharted waters for me; but an email to Cypress should disclose whether their scanner is capable of this edit. Thank you for your suggestion!
loanrangie Jan 28, 2024 07:28 PM
Better of with the Gap tool as its cheaper and just an easier unit to use.
tracyc Jan 29, 2024 10:09 AM
Fixing this issue for the community is one of my priorities over the coming year. I will be data logging all communications to and from the ride level control module, and seeing what it will take to hack that system to emulate a functioning air suspension. Then ideally coming up with a plug and play circuit board/module add on box that does NOT cost a ridiculous amount and is readily available. Whether you're buying a whole set of coils/shocks etc at the same time or not.
I love the air suspension in these, but I like having a choice even more.
I get that Atlantic British/Dunlop have no incentive to make the box available on its own as they want to sell the entire solution and have no competition currently.
This isn't happening in the next month or two, but over the course of the next year, I hope to have beta versions to send out to you guys for testing.
If any of you have ideas or requests around this, PLEASE post them here. AB has had a monopoly on this long enough I'd say. Let's make something happen - I certainly won't be able to do it without you guys.
rob bartleman Jan 29, 2024 11:48 AM
In my books you get a hundred cosmic brownie points for this undertaking you have in mind!! My skillset couldn't even touch this kind of project.... so I am not sure how I could be of much "help"......but Winnipeg has an informal LR3 club, and there are four of us who have coils, and no reflash modules. Serving as beta testers would be terrific. (And being customers for your module would be excellent!)
tracyc Jan 29, 2024 11:59 AM
Haha thanks so much man! Yeah, it's kind of a big undertaking when I've got customer vehicles lined up out my door and am turning away work already.
But - somebody's got to do it, right?
While I'm still in the planning stages, if you guys want to talk about what you would be looking for beyond turning off air susp. etc fault lights when running coils that would be a good place to start.
The module could also just have a quick kill switch to disable the air suspension, kind of like pulling the fuses does when it's trying to drop you down to the ground in fault mode, and you need it to stay aired up to get home, that sort of thing....
loanrangie Jan 29, 2024 06:39 PM
I love the EAS and will never convert to coils but for those that do an alternative module would be a blessing i think, good luck with it.
