Replacing Key Cylinder
Old Sep 28, 2021 | 02:40 PM
Matthew Lord's Avatar
Default Replacing Key Cylinder
Looking for thoughts on approach to replacing the key/ignition cylinder on my LR3. I've been advised that I need to take it to a dealer. All I'm seeing is $$$. I do have the Gap tool which should allow me to reprogram keys although I've never looked into how exactly to do that. Anyone have experience with this?
Old Sep 28, 2021 | 08:59 PM
DakotaTravler's Avatar
Pretty sure you need a working key then turn the cylinder and push a pin within the column to release it. At least that is how most are. You need a working key to program more keys with the GAP tool.
Old Sep 29, 2021 | 07:01 AM
steevo67's Avatar
If you're just replacing it because it is worn out/broken and you have the key then it isn't too hard. You'll have to remove the plastic surrounding the column to get at the hole to release the cylinder. This video shows how to release the lock cylinder:
You don't need to re-program keys, you just need the blade cut to match the new lock cylinder. If you don't have the keys, I'm not sure how you would do it. Also, I'd test the actual ignition switch if you're troubleshooting ignition/key position related electrical problems before replacing the lock cylinder.
swissarmychainsaw
May 1, 2021 02:41 PM
ElVerde
Oct 10, 2019 12:06 PM
ebindustries
Oct 28, 2017 11:57 AM
R White
Jan 31, 2013 11:38 AM
iplayblues4u
Jun 30, 2010 06:02 PM
