Replacing missing underside bolts, need parts help
I realized I have a number of missing bolts under the front of my LR3 and I'm looking to get some replacements (OEM or at least good quality that won't deteriorate quickly considering their location and the fact that I have to get some of them out to change the oil).
A few of the bolts from the main skid-plate, I'll probably get all new. I think these are KYG500500G but the bolts that were in there have a nut on the back side as well. Seems confirmed by the diagram here (HN2): https://cimg1.ibsrv.net/gimg/landrov...65e5084a37.jpg What's the part number for the nut (HN2)? Are there different bolts based on placement on that plate (see HB6)? All of the bolts that hold the plastic underside of the bumper cover to the frame are missing. I wasn't able to find these on any diagrams. Closest I could find was on this diagram of an aftermarket metal front skid plate: https://cimg6.ibsrv.net/gimg/landrov...2a6f7f4521.jpg I'm looking for part number 4, listed as M6X35, and the washers. Can I just get any M6x35 bolt? Not sure how much of this is specific to this metal aftermarket skid plate. Thanks! |
For the splash guard bolts, 05' and 06' had captive nuts, 07' on was a separate nut for 2 of the bolts.
Here is the hardware needed for the 2 splash guards, 05/06. Lr3 under plate 10 X m10-1.5 X 25 flange bolt 2 u nuts 2 X m6-1.0 X 16 flange bolt 2 u nuts The bolts also use 2 nord lock washers per bolt. |
...why does your 2nd drawing say RASTA on it? Is it from an aftermarket skid plate?
"diagram of an aftermarket metal front skid plate:"
My bad I didn't read that part at all!!!
Originally Posted by abran
(Post 601323)
Here is the hardware needed for the 2 splash guards, 05/06. Lr3 under plate 10 X m10-1.5 X 25 flange bolt 2 u nuts 2 X m6-1.0 X 16 flange bolt 2 u nuts The bolts also use 2 nord lock washers per bolt. Still looking for the front bumper cover bolts as well. |
The larger u nuts would replace the nuts you looked up.
the smaller ones are present on the front splash guard on all years. |
