Replacing missing underside bolts, need parts help
Old Mar 27, 2017 | 12:14 PM
djkronik57's Avatar
Default Replacing missing underside bolts, need parts help
I realized I have a number of missing bolts under the front of my LR3 and I'm looking to get some replacements (OEM or at least good quality that won't deteriorate quickly considering their location and the fact that I have to get some of them out to change the oil).
A few of the bolts from the main skid-plate, I'll probably get all new. I think these are KYG500500G but the bolts that were in there have a nut on the back side as well. Seems confirmed by the diagram here (HN2):
What's the part number for the nut (HN2)? Are there different bolts based on placement on that plate (see HB6)?
All of the bolts that hold the plastic underside of the bumper cover to the frame are missing. I wasn't able to find these on any diagrams. Closest I could find was on this diagram of an aftermarket metal front skid plate:
I'm looking for part number 4, listed as M6X35, and the washers. Can I just get any M6x35 bolt? Not sure how much of this is specific to this metal aftermarket skid plate.
Thanks!
Old Mar 27, 2017 | 01:25 PM
abran's Avatar
For the splash guard bolts, 05' and 06' had captive nuts, 07' on was a separate nut for 2 of the bolts.
Here is the hardware needed for the 2 splash guards, 05/06.
Lr3 under plate
10 X m10-1.5 X 25 flange bolt
2 u nuts
2 X m6-1.0 X 16 flange bolt
2 u nuts
The bolts also use 2 nord lock washers per bolt.
Old Mar 27, 2017 | 02:07 PM
houm_wa's Avatar
...why does your 2nd drawing say RASTA on it? Is it from an aftermarket skid plate?
Old Mar 27, 2017 | 02:16 PM
abran's Avatar
"diagram of an aftermarket metal front skid plate:"
Old Mar 27, 2017 | 02:23 PM
houm_wa's Avatar
My bad I didn't read that part at all!!!
Old Mar 27, 2017 | 03:33 PM
djkronik57's Avatar
Lr3 under plate
2 u nuts
2 u nuts
Thanks Abran, this will be great for those with 05/06. Looks like KYG500500G is the 10 bolts I'll need, doesn't seem too different for a 2008, but I don't think I had any U nuts on mine. Maybe they got rid of them or they just rusted away? Nor any lock washers for that matter, and some had nuts on the bolts (I think at least 4 of the 10). Maybe that was just a result of not having the correct bolts with the lock washers?
Still looking for the front bumper cover bolts as well.
Old Mar 27, 2017 | 03:51 PM
abran's Avatar
The larger u nuts would replace the nuts you looked up.
the smaller ones are present on the front splash guard on all years.
The-J-Man
Jan 18, 2025 06:43 PM
keoni004
Dec 6, 2013 09:15 AM
coors
May 11, 2011 08:14 PM
Savannah Buzz
Feb 25, 2011 10:23 PM
avking
Feb 18, 2009 05:10 PM
