-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Rounded Bolt (https://landroverforums.com/forum/lr3-28/rounded-bolt-66300/)
revel8or Apr 6, 2014 02:20 PM
Rounded Bolt
So, I started to change the oil this weekend and found that 3 of the skid plate bolts were rusted tight. I broke a socket trying to remove one, so I took it to a local oil change/service place - been using them with my other cars for 7 years with no issues. They called 15 mins later and said that they had broken two sockets trying to remove the bolts.
Today, I got under and found that what *really* happened was that they successfully loosened two of the bolts, but the third stuck one was rounded off. Nicely rounded off. I don't want to spend the time drilling and rethreading, so it's off to a mechanic...all for an oil change.
Although, I did put anti-seize on all of the other bolts...
sincity Apr 6, 2014 04:34 PM
should take it back to the oil change place, or buy the socket remover set by irwin at local autoparts store. the set really works
coors Apr 6, 2014 08:03 PM
Assuming there is access to the bolt: Get a Dremel w/ a cut off wheel and cut a slit in the head of the bolt large enough to wedge a large flat blade screwdriver. Voila.
spiderman Apr 7, 2014 10:08 AM
so you can't turn a bolt with six points of contact and a 14 inch long ratchet and you figure a screwdriver with two points of contact with basically zero leverage and zero torque will work...
This is the solution.
http://www.irwin.com/uploads/product...actors-802.jpg
Combined with heat from a torch to use the expansion of the hot metal to help break the rust. (If available)
or a long breaker bar, pipe, anything to add leverage.
or an impact gun...
and if it breaks the bolt, drilling and an easy out is the answer,
http://www.homehardware.ca/products/300/11204141.jpg
if none of the above remove the bolt, re-threading (or drilling and installing a bolt with a nut if possible) is the solution.
But a lack of tools leads to only one solution: paying someone else to fix it. Personally, I prefer to spend money on tools rather than shop labour. Any tool in a tool box will pay for it self in the savings on labour and shop charges.
The best advice regarding broken sockets is to invest in a set of impact sockets. they still fit on a ratchet if you don't have an impact gun, but are pretty close to indestructible.
http://imgs.inkfrog.com/pix/idrack/3570022.jpg
bbyer Apr 7, 2014 10:33 PM
bolt extractor sockets look effective
I have always had the best luck with the spiral EasyOut as shown above. That was a good post with the two pictures - I like that.
It may however be because I have never used the Irwin sockets before. They look pretty effective and easy to use - certainly easier than drilling and you still have that option when the head twists off.
Screw & Bolt Extractors - Tools - IRWIN TOOLS
What bothers me most however is wondering if the 3 has ever had an oil change previously. How can studs get rusted in that badly?
d7sec Apr 8, 2014 03:47 PM
I broke couple of Craftsman bolt extractors before buying this one. It costs like a whole Craftsman kit, but is right on the job.
https://landroverforums.com/forum/at...a-snapon16-jpg
unseenone Apr 8, 2014 06:59 PM
That ol' adage, you get what you pay for applies here... Neat stuff, I can't stand easy outs, never had any luck with them. I found it was easier to carefully drill out everything but the threads.
LR Techniker Apr 8, 2014 07:47 PM
Those extractor sockets have yet to let me down. Worth every penny if you work on automobiles.
