Rpm goes to almost zero at cold start
Hello guys,
I have a 2007 LR3 HSE w/ 75K + miles (runs great). Most of the time when I start the vehicle in the morning (after been parked overnight in a garage) the idle keeps falling down close to zero RPM as if the engine is about to die....what could be the reason here? I let it warm up for 2min or so, and still goes up and down from 2 to almost 0. The car won't die on me tho, fortunately,...... but it seems frustrating. This issue doesn't happen while I'm driving the car or at a stop sign, only when I start the car in the mornings or after it has been parked for several hours. Thank you in advance for your help.
Jeff
Jeff
Jeff, I am having what seems to be the same problem except maybe not as advanced. How long has this been going on?
About a week ago mine started doing what you are describing and has gradually been getting worse. At first it would just dip rpm slightly at start and come back up immediately. Now it almost dies, and after 1-2 seconds returns to normal high idle at start up for a minute or 2 to warm up.
I just cleaned my throttle body, but I suspect this is not my problem as I just thoroughly cleaned it 6k miles ago. I also just cleaned my MAF and that did not help.
Only other thing I can think of is something going on with the injectors, but my LR3 runs perfectly except on a cold start. Maybe I will buy some of the BG 44k and put that in before either trying an injector flush or taking it somewhere.
Anyone have any other thoughts? Could this be something with the EGR, or PCV valves? I know very little about these systems.
I think I resolved my issue. I used Lucas fuel treatment and injector cleaner. It seems to have done the trick.
My thoughts on how my problem started: A couple of months ago I changed from Chevron gas to Shell gas simply because there was a Shell close to my house. Shortly after this is when I started experiencing the problem. My thoughts are that maybe Chevron gas cleans the system better. We will see if the problem comes back.
Let us know how it goes.
When I moved from California to Indiana I had to make the same switch from Chevron to Shell and my rover does the same thing. I believe Chevron is the better fuel IMO. My RPM dips too in the morning, but I am about to try and engine flush with spark change. See what happens. Fuel treatments don't really have any effect from what I can see.
atikovi
03-27-2016 09:05 PM
marlymarl
04-21-2012 12:49 PM
wuzin
10-25-2008 03:07 AM
Jupiter Rover
06-09-2008 08:18 PM
key59
11-03-2005 02:08 AM
