Snow trouble.
RE: Snow trouble.
Stock tires are horrible in snow. I live in Denver and got stuck after a big snow storm last December. I traded in a Z71 Tahoe for the LR3 and ironically got "pulled out" with the help of a Chevy Tahoe. Stock tires also wear out quickly. Dealer told me the back tires needed to be replaced at 15000 miles due to the LR3 being out of alignment. They gave me one free and I paid for the other which was the only reason I stayed with the GY tire. I did a lot of research and found out the stock tires wear down fast. 3000 miles later needed to replace the front tires. I wish I would have just replaced all tires with new A/Ts. Plan to buy new A/T tires (Wangler Silent Armor) around the end of the year before winter and use stock tires as spares.
Anyone know if the Wangler Silent Armor last considerably longer than the Wangler stock tire?
RE: Snow trouble.
I have had similar problems in the snow, especially DEEP snow...seems I turn off the DSC, but something is still telling the brakes to activate. It just saps the power out of the truck & overheats the brakes & the transmission. Is there a way to FULLY disable the DSC? In the winter, I do a bit of off-roading & driving on the lakes in the area and it is really annoying to have Jeeps pull me out of the snow every 50 yards....[&:]
I did change from the stock tires to the 285/60/18 Nittos, but I think that ifI could turn off the DSC completely, it would do much more!
It is really sad that this 'high-tech' $50K vehicle can't compete with a $20K pickup in the deep snow. I think that all of the electronics are a complete waste. Sorry for the rant.
RE: Snow trouble.
Gessler, because I have learned not to assume anythingI'm going to try to clear the obvious first and hope I don't insult your inteligence. Are you sure you are turning off the DSC? Just pushing the button doesn't turn it off. Have to hold the button pushed for several seconds until the DSC light comes on the dash.
Perhaps it is me who has not payed close enough attention but the times I have played with the DSC off I did not notice it taking over the braking at all. Also, I would look into usingmud setting instead if Ice settingwhen in deep snow so the traction control will allow a lot more wheel spin. The Ice/snow setting forces you to start in 2nd gear (3rd gear when in low range) and greatly increases the sensitivity of the traction control over tires spinning, which is bad newsin deep snow.
RE: Snow trouble.
I just got a 2007 LR3. It has the Goodyear Wrangler H/P's. Are they any good in the snow?????
Also, I have Bridgestone Blizzak LM-25's on my E430 4-matic and the tires are awesome. I would slap the Blizzak's on the truck if I were you.
Are you in NJ? Looks like you got your LR @ Prestige in Paramus - ME TOO
