Special Programs Off
Old 02-20-2019, 09:41 PM
sickws6's Avatar
Codes. There are several sensors in the system and items read. For example, amperage draw of the compressor is read. Pulls too much power, assumes there is an issue. Also the reservoir air tank pressure is monitored. If it builds too slowly, fault. And the list goes one. The basics can probably be figured out without codes though. First thing will be a hard-reset of the vehicle when you get it (disconnect battery for a few minutes, make sure you power down the car and WAIT a couple minutes before disconnecting! - Lets the computers power down to a safe state). Then go from there.
Great! Is there a process where after you disconnect you connect the positive to negative cables?
Old 02-20-2019, 09:42 PM
DakotaTravler's Avatar
Just disconnect, there is no need to connect them together. You can if you want, but science and physics says there is no point.
Old 02-21-2019, 06:20 PM
sickws6's Avatar
Ok. O also cruise control doesn't work. Getting a fault with that as well
Old 10-13-2020, 05:32 AM
ravidlin01's Avatar
Default Special program off terrian response is not available
Hello Dear,
my car is show like this, I don't know how to set up on.. Can you guide me to solve this...
CollieRover
07-10-2021 07:34 PM
parksy
02-08-2021 06:39 PM
grammin
04-21-2020 09:20 PM
acg
12-24-2014 10:04 AM
discoboy
11-08-2011 03:16 AM
Quick Reply: Special Programs Off
