Tire Pressure Monitoring System Module Failure
Air suspension is doing nothing...at all. Mechanic tried replacing the relay with a used one to see if that was the problem....and they said it worked very briefly, (due to it being the wrong amp relay). They ordered a new relay and tried it the next day, but it didn't do anything. Now I'm just bouncing around.
I don't suppose you know if that compressor is an AMK or Hitachi, do you?
The Hitachi was the original OEM unit, then due to supply chain issues (tsunami) Land Rover sourced compressors from AMK (a German outfit). That occurred around 2011. When they switched, the relay needed to change, and when the AMK was installed the software needed to be updated. It's possible that your mechanic installed an AMK in place of a Hitachi and either didn't update the relay or the software; or both.
Misti (06-25-2022)
