Transmission control module on an LR3
Old 06-13-2022, 11:29 PM
discobaja's Avatar
Default Transmission control module on an LR3
Hello
I have been researching but can't find any solid information on where is the transmission control module on an LR3 and don't mean the transfer case control module behind the battery i already changed that. Some people on the internet say its under the drivers seat and others say its on the tranny. I have an error code U0101-87 and i need to check my TCM. Any solid information would be aprecciated.
Thanks
Old 06-14-2022, 08:27 AM
P-Bod's Avatar
It is attached to the valve body. #13 in this picture:
Old 06-14-2022, 08:56 AM
P-Bod's Avatar
According to Mitchell 1 DIY's wiring diagram, the ground for the TCM at the Left A Pillar. I believe that is behind the driver's side front inner fender. I know there's a ground post or two in there. That might be a good place to start troubleshooting.
Old 06-14-2022, 09:12 AM
P-Bod's Avatar
OK, not in the fender... Here it is in the "A" Pillar:
Old 06-14-2022, 08:30 PM
loanrangie's Avatar
As per the above diagrams its inside the transmission, U codes are only communication errors but does it come back after clearing ? Any other dash messages or trans related error codes ?
Old 06-14-2022, 08:41 PM
DakotaTravler's Avatar
A leaking Mechatronic sleeve can allegedly cause issues. Is that sleeve new, old or leaking? Its the main connector to the transmission. A part very often replaced with an updated design.
Old 06-25-2022, 01:24 PM
discobaja's Avatar
Thanks, its a little bit more involved than i though, but i need to do a tranny service anyway
Old 06-25-2022, 01:25 PM
discobaja's Avatar
Thanks for the info, ive been super busy havne't had time to mess with the Disco but ill look into those diagrams. Thanks a lot for responding
Old 06-25-2022, 01:26 PM
discobaja's Avatar
It is leaking a little bit, i have to do a tranny service anyways so i guess ill pay once and cry once with this one
Old 05-21-2023, 07:27 PM
cesarini90's Avatar
Hi guys,
I've just seen this post and I have a follow up question. My 2008 Disco 3 has just "died". It doesn't start and mechanics say it is the Transmission Control Module (TCM) that needs to be replaced. They ask for 8,000 bucks which is a lot of money so I am trying to find that part elsewhere. Does anybody know what is the serial number OEM of that part?
Thank you so much
BR
Cesar
Quick Reply: Transmission control module on an LR3
