comleader, yeah I had to jack up the engine and unbolt part of the exhaust.
That's another reason why I did the steel pan conversion. With the steel pan, you don't have to raise the engine. Plus, like I said above, you can buy a new tranny filter without having to buy a whole new pan. If you're interested, I can get you a list of the part numbers plus give you the contact info of the company I sourced the parts from. Let me know. |
Originally Posted by er1c
(Post 405112)
Originally Posted by comleader
(Post 405203)
Thanks. I would really appreciate that.
comleader,
For the steel pan conversion, the part numbers are as followed: Steel pan: 1068-203-042 ($117.81) Bolts (21 of them): 0736-010-347 ($2.45 * 21 = $51.45) Replaceable Filter: 0501-213-359 ($47.36) Gasket: 1068-303-017 ($22.82) I ordered them from "Eriksson Industries" erikssonindustries.com. They're located in Connecticut and I recommend them. It took about 5 weeks to special order the parts from Germany until they arrived at my house. My receipt came out to a total of $250.50. |
Took mine (05 LR3 HSE) to my local Indy (independent shop) and they changed filter, flushed trans and refilled with new complete fluid fill for about $280 and that was using a Land Rover OEM trans filter with gaskets, replacement o-rings including the filler tube o-rings.
Originally Posted by rewillia
(Post 406549)
One method I've heard is a "double flush". Drain then refill. Drive it to mix the oil. Then drain and refill again. Yes there will be some old oil left (max 25%) but you've replaced at least 75% of the oil. |
I did changed my trans oil on my lr3 2006 with 130000km by flushing 10 liters and is fast and great!!
(Post 405112)
That's another reason why I did the steel pan conversion. With the steel pan, you don't have to raise the engine. Plus, like I said above, you can buy a new tranny filter without having to buy a whole new pan. If you're interested car zinity, I can get you a list of the part numbers plus give you the contact info of the company I sourced the parts from. Let me know. |
Flushing 10l motul mult atf
Originally Posted by irontmp
(Post 916674)
I was at the dealer and they are saying when MM says change trand fluid, they remove all the fluid via a machine and replace it with new repalcing almost 110%. I was under the impression using a machine on the trans is no good what gives ? Anyone dealt with this situation ?
I think the issue with using a machine is the filter is not replaced. But really the filters last a wicked long time and its not like engine oil that can get contaminated. I would have no issue using a machine with the only caveat being that I would want the filter changed at no more than 200,000 miles. I think that is plenty for any modern trans filter.
| All times are GMT -5. The time now is 07:48 AM. |
