using oil extraction pump for oil change
I've never actually checked the threads. Then again, I never really gave much though to the drain plug at all; I've uhad zero worries about stripping it. Steel bolts into aluminum aren't exactly anything new. Of course I do my own oil changes and don't take it to the quicky-lube monkeys either.
As for the oil extractors I have several and use them regularly - just not on my cars/trucks. In the boat world you have to either suck the oil out from the dipstick or have a drain system plumbed into the pan since you can't exactly get a catch can under the engine when it's sitting in the bottom of the bilge. I'm not a huge fan as they never get all of the oil and you just know the worst crud will be built up in the lowest point. It's also nice to have a magnetic drain plug you can inspect when you remove it.
collin Barrows
Aug 28, 2011 07:13 AM
