ndinsmore |
10-16-2018 03:08 PM |
VCT/VVT Sprocket Replacement help
So I have a 2007 LR3 4.4L V8 with about 118K miles. For about a year I have had the dreaded cold start VCT banding at start up that has slowly gotten more and more common on every start. So it looks like I am going to replace the VCT Sprocket here soon. Since it appears that I am going to have to take of the entire front half of the engine the questions is what additional maintenance should I do? I think it is only banging on one bank but should I replace the sprocket both sides? Should I also replace the timing chain tensioners while I am in there? There appears to be no consensus on that. An advice would be greatly appreciated.
