VCT/VVT Sprocket Replacement help
Old Oct 16, 2018 | 03:08 PM
ndinsmore's Avatar
Default VCT/VVT Sprocket Replacement help
So I have a 2007 LR3 4.4L V8 with about 118K miles. For about a year I have had the dreaded cold start VCT banding at start up that has slowly gotten more and more common on every start. So it looks like I am going to replace the VCT Sprocket here soon. Since it appears that I am going to have to take of the entire front half of the engine the questions is what additional maintenance should I do? I think it is only banging on one bank but should I replace the sprocket both sides? Should I also replace the timing chain tensioners while I am in there? There appears to be no consensus on that. An advice would be greatly appreciated.
Old Oct 16, 2018 | 10:56 PM
abran's Avatar
Tensioners and guides are a no brainer .
you need the timing tools to lock down timing on both heads and flywheel before removing anything. Also need the pulley remover tool.
means both valve covers have to come off as well as front cover
Old Oct 17, 2018 | 07:40 AM
Nosugar0carbs's Avatar
What’s not to say the sprocket chain is the culprit? Valve cover seals, front crankshaft seal, Front cover seal, Oil service, Spark plugs. Belts. You have to touch all those anyhow.
Old Oct 17, 2018 | 08:13 AM
abran's Avatar
I was assuming the seals would be changed as you don’t reuse those
Old Dec 9, 2021 | 07:25 PM
JN5LR3's Avatar
Hey, did you ever take on this project, and if so how did it go?
Twix
Sep 1, 2018 04:24 PM
motoexclusive
Aug 17, 2018 01:35 PM
Prime519
Jul 14, 2018 03:53 PM
aemnky606
Apr 26, 2015 09:47 PM
brianb883
Mar 13, 2012 07:52 AM
