What Nut does this Hardy Spicer (LR3) Use? Where can I find it?
Old Apr 23, 2022 | 12:22 PM
dnbrown9's Avatar
Default What Nut does this Hardy Spicer (LR3) Use? Where can I find it?
Replacing my rear axle half shaft on the driver's side of my 2006 LR3 with locker. Bought a Hardy Spicer, pictured here: https://lucky8llc.com/collections/lr...r-lh-genuine-1. It didn't come with a nut and it's not the same pitch as what I pulled off. What I pulled off has a notch in the threads to "lock" the nut. Did some recon and am wondering if part number LR024151 is the correct nut for the new shaft. Do you know or have thoughts you'd like to share? Photos are below.
Original on top, pictured with nut. Hardy Spicer below, need nut.
Original, notch, and nut.
Hardy Spicer, notchless, nutless.
Old Apr 24, 2022 | 07:48 PM
DakotaTravler's Avatar
There are two style o nuts due to updates. I always keep a few of each on hand because they are cheap and they are not reusable.Axel nut:
RFD500020 (thread = m24x1.5)
LR024151 (thread = M24x2.0)
Also the torque spec has been updated. I think something like 250 ft lbs versus the older torque of 320 ft lbs - or something like that.
Old Apr 25, 2022 | 10:41 AM
dnbrown9's Avatar
Thanks! I appreciate this!
Old May 4, 2022 | 12:27 AM
dnbrown9's Avatar
Update: Lucky8 sent me the RFD500020 nut. I can only get a couple turns on it by hand, not even half the nut. So, I don't think it's correct. I'm awaiting the arrival of the LR024151 nut. The search continues.
Old May 4, 2022 | 06:31 PM
Correct. The updated shafts and nuts have a courser thread, hence the 2.0 pitch versus 1.5. Also, for the record, I think the old ones were 32mm and the new 36? I could have that backwards. As for install, the new ones will be castle nuts so just torque and there is not cotter pin or a need to dent in any metal to ensure they hold Makes me nervous but that is what I was told and mine have been fine for year. I think the important thing with the new ones is they are one time use for sure whereas the old ones you cold get away with re-using I suppose.
Old May 4, 2022 | 06:32 PM
FYI if you have an O'Reilly Auto Parts they may have both nuts in stock. They, oddly, seems to stock a good number of Rover parts.
Old May 9, 2022 | 04:50 PM
dnbrown9's Avatar
The LR024151 is in fact the correct nut for the Hardy Spicer left rear axle half shaft, locker edition. I ended up using Atlantic British and will make future purchases from them as a result of my experience with Lucky8. Thanks all for your help! I REALLY appreciate it!
Old May 9, 2022 | 04:53 PM
Yeah, I have had no luck with Lucky8 either so I no longer buy from them - not that I had the chance to buy much anyway. AB is good and so is LR Direct.
Edward0123
Jan 24, 2022 08:06 AM
vanbadri
Nov 6, 2018 05:27 PM
DakotaTravler
Oct 13, 2018 12:30 PM
AlaskaKaz
Aug 18, 2015 09:12 AM
