20” RRS Wheels on LR4-Do they Fit?
I have the opportunity to buy some 20 inch wheels off a 2018 RRS, they have 255/55R20 which is virtually the same as the 255/60R19s on my 2011 LR4. My question is, has anyone put these wheels on an LR4? Does the offset cause any problems? How do they look? Also, will I be able to use my LR4 lug nuts?
Offsets do affect handling. However many seem content with so called “improvements.
Do you know this resource:
https://www.wheel-size.com/calc/
In particular, the scrub angle has an effect on handling and this is exemplified in adverse conditions. Of course if the vehicle is used as a mall crawler, I don’t suppose it matters.
I find it interesting you have a desire to go to a lower profile tire…. as I am quite the opposite. I find the 19s I have too low as it is…
Cheers!
Cheers!
Cheers!
Cheers!
20s def fit as they made oem 20s for the LR4. the offsets are the question as you can see i went through this here:
https://www.landroverworld.org/threa...r072689.45382/
different offsets are not necessarily a deal killer depending on magnitude.
