Any model with the 5.0 can have the noise I'm referring to. It presents any where from a tick to a low level knock at idle, but goes away when RPM's are increased. Once you know what it sounds like you can hear it on almost all of them.
I Just bought a 2011 LR4, not new to Rovers or Brits but new to the 5.0. I have this noise and spent all weekend researching this. Just to revist, this "knock" is normal? Timing Chain guides/tensioners have been done along with water pump and thermostat.
(Post 576698)
The "knock" you hear at idle is the fuel pump cam follower.
The 5.0L engine uses mechanical fuel pumps, and the cam follower can be very noisy. It sits lower in the engine so it sound like something in the bottom end, but usually it's not. |
anyone? anyone ?
This makes sense, I added sea foam to the tank and the knock all but disappeared.
I’ve used BG44k and no such luck decreasing my idle knock
Did the knock stop after the seafoam or any other solution to stop it?
Hi all, I wanted to also note that I’ve got the same knock. I think?! Video does capture the sound. Would you guys mind letting me know that it’s what you experience too? Thanks
https://drive.google.com/file/d/1R3Y...ew?usp=sharing |
Video link seems to be broken.
