2011 LR4 Only Normal Height Available
When it says "Normal Height Available Only" will it throw a code? My LR4 does this intermittently but after the engine is cut off and I start it up again the warning lamp and message is gone. I have also noticed that after I park and turn off the vehicle my suspension will lower some on front and/or back. I am not sure if this is normal, I have only owned the vehicle 2 weeks. I have a code being thrown for the camshaft positon.
It should throw a code. As for the vehicle lowering after parking, it is normal for the car to let some air out after offloading some weight (the car is just adjusting back to proper height), or if the car is parked on an uneven surface (car will let some air out to level a bit). But, if you are coming out to the car kneeling front or rear in the morning, or tipped on one side or corner, this is not normal. And don’t ignore that camshaft position error, especially on a 2011 car - they are known for timing chain problems. If you bought the car used from a dealer, get it back there pronto to have it checked out. I believe most states require dealers to offer at least a month of warranty on a used car.
