Could be the start of a wheel bearing failing. We are just assuming a diagnosis through the interweb |
Originally Posted by Nosugar0carbs
(Post 663257)
How many miles? I would assume a higher mileage due to extended warranty. Check the wheel bearings. Jack the front up and jiggle the wheel sidexside and up/down for excessive play. |
@Axelander any updates?
Do you know about this? Technical Bulletin No: LTB00305 (issue 1) dated 13 Aug. 2010 Section: 308 Audible Boom / Vibration @ 2,600 - 2,800 rpm http://australiancar.reviews/_pdfs/SB-10069796-0699.pdf |
No change with mine. I installed that TSB, may have reduced the vibration a bit but did not fix it completely. The hole that the TSB damper screws into is not tapped... so you have to tap it yourself.
I picked up a 2013 LR4 earlier this year that had the same symptoms. I did a bunch of research and found the TSB and ordered the parts and installed myself like previously mentioned. I had to tap the transfer case for the bolt which wasn't a big deal. It took care of most of the vibration/resonation that was happening at those RPMs. Well worth doing IMO.
