2014 LR4 HSE LUX SV6 Alternator Connector
Old Mar 14, 2026 | 01:09 PM
sraspa's Avatar
Default 2014 LR4 HSE LUX SV6 Alternator Connector
Hi,
I'm replacing the alternator in my 2015 LR4 HSE LUX SV6 and when I tried to disconnect the alternator connector, the wire (single wire) broke at the connector. Any suggestions on what to do? Do I need to replace the entire wiring system for this connector? Or do I simply just need to replace the connector and put the old wire into it? Any recommendations are appreciated.
Thanks,
SR
Old Mar 14, 2026 | 05:24 PM
Lowrykun's Avatar
I'm glad you asked... I did the same thing and I posted my solution here along with an video:
https://landroverforums.com/forum/lr...rnator-100386/
The original LR part number is YPC908520 ( thanks to Lutron); However, if you want a more immediate solution, you can get a Duralast CONA357 in stock at Autozone for $20. The connector is the same, but it's two wire; the LR part is one wire. Just cut off the extra wire (be sure you cut the right one off ) and discard it. Use a waterproof crimp butt to connect it.
Old Mar 15, 2026 | 09:02 AM
sraspa's Avatar
Thank you! If I go with the Duralast part, how do I know which wire to cut? And how do you connect the existing wire to the duralast part?
Old Mar 17, 2026 | 07:14 PM
Lowrykun's Avatar
You look at the old connector and the new connector and cut the wire that the old connector doesn't have
I assume we're talking about the same part. Did you check the link I provided? I don't know where your wire broke (which side of the connector). Yours might have broken in a different spot than mine.
LJRLR4
LR4
Jan 20, 2026 10:40 PM
Francisco M-Torres
LR4
Jan 20, 2026 10:18 PM
Bart_Groff
Dec 24, 2023 07:04 PM
Rufflyer
Apr 26, 2020 03:05 PM
Gonow
Feb 12, 2019 08:49 AM
