2015 LR4 fuel problems
My 2015 LR4 has been getting worse and worse for dying. It will run great, then stall and not start again. It is a fuel problem. Each time it stalls the low fuel pressure code gets thrown. A new fuel pump and fuel pump driver module have been installed- Same problem occurs. Changed out the crank position sensor…. Same problem. Fuel pump relay was changed , still the same problem. When the local shop pushes it into a bay for testing and connects the diagnostic tools it will start again. Not sure if it’s a bad ground? Or a sensor. All help appreciated
