2016 LUX, option questions
Hello
I am looking at buying a 2016 HSE LUX. I have spent about 50 bucks in different “build sheet” and “window sticker” online sources, monroney included, and I am unsure if they are entirely accurate as they have offered conflicting info. Monroney Labels online has this with NO optional equipment.
The VIN comes back as an HSE LUX. It has the LUX seats. It has silver roof rails (Landmark?) and Landmark badging on the rear and both sides. It has black wheels, side vents, and grille, but NOT the black LR4 badging on the rear (Partial “Black Package”?) It also has black lacquer trim inside, unfortunately, because I love that straight grain trim. May consider swapping, the black lacquer just looks like shiny plastic to me, and shows everything. So is this a HSE LUX LANDMARK?
what else can I do to determine what this car actually is, and what options is has. I know LR is known being customizable with a plethora of options, not unlike my other car (Porsche), but I’m really having a tough time pinning down what options this car has. my research shows it seems the final production LR4s were a bit hodgepodged together.
thanks.
thanks.
In the past it was possible to check the build sheet from JLR’s TOPIx service. Not sure if that is still available. All you needed to do was register and then submit your VIN. From memory, if any feature is prefixed with “LESS” it meant that it was not included.
Also, as you rightfully note, the end run vehicles could have whatever on them subject to parts availability at the factory.
It's a LANDMARK. All LANDMARK were "HSE LUX" Black trim with leather dash is a dead giveaway. https://www.landroverdarien.com/land-rover-lr4-trims/
