-   LR4 (https://landroverforums.com/forum/lr4-38/)
-   -   Ac does not work. GAP log inside (https://landroverforums.com/forum/lr4-38/ac-does-not-work-gap-log-inside-118624/)
newdude Sep 2, 2023 02:46 AM
A/c does not blow cold. Here are the screenshots. Any help or anything else needed from the gap tool please lmk
https://cimg8.ibsrv.net/gimg/landrov...58157e3ea.jpeg
https://cimg9.ibsrv.net/gimg/landrov...538a53978.jpeg
steevo67 Sep 5, 2023 09:10 AM
The System pressure is a little high, and your evap temp is way too high. There are several things that can cause that, you'll have to put a proper set of gauges on it to see the hi & lo pressures and see what they do when the compressor cycles.
guy Sep 7, 2023 07:29 AM
Easiest fix first. was the fluid recently 'over' topped up...
