Creak-Squawk Suspension
Have a creak-squawk in my suspension that is periodic. Only happens at slow speeds going over small bumps. I can also replicate the sound when pumping brakes at a stop light; sound is a bit different.
Pushed on the suspension in my garage and couldn't replicate. Jacked up the car and inspected all bushings I could leverage with a pry bar. Nothing seems to wiggle easily; a bit of play in the front control arm rear bushing (bigger one); seems normal. Replaced sway bar bushings, stiffer ride, but still squawks. I'm sure some experienced techs have seen this before. Ideas? How do I diagnose? 2011 LR4. Thanks. |
My 2011 LR4 has the same problem. I too, replaced sway bushings. Sounds as if shock bushings, but, I know at 90K I need to do all suspension bushings and eventually shock bushings when I do shocks.
