Creak-Squawk Suspension
Old Apr 14, 2019 | 10:00 AM
quirozson's Avatar
Default Creak-Squawk Suspension
Have a creak-squawk in my suspension that is periodic. Only happens at slow speeds going over small bumps. I can also replicate the sound when pumping brakes at a stop light; sound is a bit different.
Pushed on the suspension in my garage and couldn't replicate. Jacked up the car and inspected all bushings I could leverage with a pry bar. Nothing seems to wiggle easily; a bit of play in the front control arm rear bushing (bigger one); seems normal.
Replaced sway bar bushings, stiffer ride, but still squawks.
I'm sure some experienced techs have seen this before. Ideas? How do I diagnose? 2011 LR4.
Thanks.
Old Apr 14, 2019 | 01:08 PM
Jagfixer's Avatar
My 2011 LR4 has the same problem. I too, replaced sway bushings. Sounds as if shock bushings, but, I know at 90K I need to do all suspension bushings and eventually shock bushings when I do shocks.
02D2
Nov 2, 2016 08:39 AM
kid A
Aug 6, 2015 09:54 AM
avo8230
Feb 18, 2014 06:39 PM
susie
Jun 26, 2011 07:11 AM
bmwrovers
Aug 31, 2010 06:57 AM
