Dealer Wants $5000 to replace waterpump
Can anyone chime in and let me know what's a reasonable price is to replace the water pump on a 2016 LR4? Dealer wants to charge close to $5,000 to replace the pump. When I went in the car was fine, they recommended I replace the pump based on "brittle hoses". I declined. On the way home from the dealer the car over heated, now it's back at the dealership.
That is outrageous.. My local indie wants 3500 to change the crossover pipes, thermostat, water pump, oil cooler and hoses plus a few other while he has everything open. And that included parts.
If they're quoting 5k they should be able to provide a written estimate showing what is and isn't included. Grab that from them then post it up here. I bet it includes replacement of a bunch if not all of the cooling system components like hoses/clamps/plastic tubes/etc.
Main water pump only at main dealer's usually around a grand, DIY less than $200. As others said, provide a list of parts quoted or the description of the work to be performed (some main dealers are no longer providing detailed quotes)>
That price is definitely to replace the coolant crossovers, not just the water pump. The only brittle hoses are the crossover pipes. I just wonder if they messed around with them and fractured one before the car left the dealership. What was the car in the shop for? Coolant leak? If not, what prompted the recommendation to replace the coolant pipes?
Quite right @jlglr4 .
I suppose its possible that the pipes are brittle…. But I have no idea where in the world @SpceWrnglr is located…
Running in very extreme temperatures, not performing the scheduled maintenance and flushing the fluid, and spilled oil are all contributors to weakened rubber.
I had the cross-over pipes replaced, new coolant, thermostat and hoses changed out. It was on our 2010 Range Rover Sport v8 non-super charged. The removal of the supercharger adds some labor to the process. Cost of labor and parts at a highly recommended independent shop in Orem, Utah, was $1,700. $5,000 is an absolute ripoff. Run, don't walk. Good luck. Phil
