Emission monitor Fuel System not ready
Time to smog the 2013 LR4. Assumed it would easily pass. I Should have checked the monitors before stopping at the smog check station.
Did a fair amount of searching with no real obvious leads. I’ll drive it a bit tomorrow and watch the monitors via my Code reader. Tech was surprised that the Fuel System wasn’t ready. Feared an ECU or wiring issue. I do see short to ground faults in the drivers mirror or door occasionally based on prior faults. The following were not ready: Fuel System (continuously monitored) Catalyst Oxygen Sensor Evaporative System (optional in CA) I hadn’t cleared the codes in quite a long time. I was on vacation recently and the battery voltage might have dipped, though it started easily. From what I’ve read, some codes can prevent the continuous monitor of Fuel System (runs at startup) should be ready unless some code prevents it. No O2, Evap or fuel codes per GAP IIDTOOL. I cleared everything and restarted it a couple of times. Still not ready. Any suggestions or experience with this? |
I remember reading this not too long ago, but I do not think you have the same faults. https://www.landroverworld.org/threa...9/#post-221784
in another thread, they talked about drive cycles and driving 100 miles at over 55mph to allow everything to reset. |
Tried hard reset and drove it for two hours today. Still not ready.
May call Gap Diagnostics and discuss an Ecu flash unless anyone else has any ideas. |
Originally Posted by Oldman846
(Post 752219)
Still not ready
I have about a hundred miles in the last day or so. No real change. Stopping by a local independent garage today. We’ll see what they think. Could be EGR or PCV. Weird that there are no codes....
Originally Posted by Geo
(Post 752703)
How many miles do you have on your LR4? I've got a 2012 with 89k. Lmk what you find out, I'll also keep everyone posted what I uncover. |
That aligns with what I think as well.
2013 with 118k miles so far. Been a great truck, not expecting anything too bad. Just have to track down the issue |
To close the loop. Drove awhile, heated cat, egr and fuel system still not ready. Egr went ready on the way to the shop. Local independent found no errors. Flashed the PCM/ECU with newest software release and tightened a Positive battery terminal that could be moved by hand. He thought that could cause an issue. $255 dollars for diagnosis and flash. I wasn’t convinced.
Less than 70 miles later, all monitors ready. Happy as a clam. Not sure what made the difference. I will say the fuel system was the last one to go green. The heated catalyst turned right before. EVAP went green after sitting overnight. So, the Fuel System monitor does not change immediately at startup even though it’s called ‘continuous.’ Documented for posterity. Here are some screen shots. The next to last counter (Secondary O2 sensor monitor) turned from 3 to 4 and then all monitors were ready. https://cimg4.ibsrv.net/gimg/landrov...b64e60ec5.jpeg https://cimg7.ibsrv.net/gimg/landrov...7f79b67c1.jpeg https://cimg5.ibsrv.net/gimg/landrov...76a6fc4e4.jpeg |
Geo this is great news. I look forward to seeing if this is what solves my problem, keep you posted.
(Post 753238)
Less than 70 miles later, all monitors ready. Happy as a clam. Not sure what made the difference. I will say the fuel system was the last one to go green. The heated catalyst turned right before. EVAP went green after sitting overnight. So, the Fuel System monitor does not change immediately at startup even though it’s called ‘continuous.’ Documented for posterity. Here are some screen shots. The next to last counter (Secondary O2 sensor monitor) turned from 3 to 4 and then all monitors were ready. Thanks |
