LR4 brake issues
LR4 brake issues
Over memorial day weekend I noticed some squishy brake feel. Now I notice that it brakes fine, but the last few feet feels like the brakes slip or something-it needs a bit more distance to stop. Of note:
-Brakes build and hold pressure fine with engine off, when I start the engine with my foot on the brakes it does sink maybe an inch or so -no Brake worn light/notice -I feel like I can hear the plenum move when engine is on and brake is being actuated, is this a bad brake booster? -brake fluid level has not notably decreased -car has ~167000 miles on it -have not recently had any brake work done before this issue -no shuddering/pulling even when applying brakes hard -occasionally I can hear a whistle when engine is at idle and I press the brakes. Only occasionally and I cannot replicate it on demand.
My culprits that my research seem to point me towards are: -master cylinder -brake booster -swollen brake lines?
My question, anyone aware of a way to eliminate any of those options as a possibility? I hate to go throwing random parts at it in hopes of a repair. Thanks!
The flexible brake hoses are rubber. They need to (= should) be changed every X years, I think it was 6 years or 156k km (102k miles roughly) whichever comes first. If you suspect them, remove a wheel one at a time and have someone inspect the hoses from the brake pipe all the way to the caliper visually while you’re pressing down the pedal.
The brake fluid should be changed (recommendation) every 2 or 3 years.
Squishy brake pedal can be many things but perhaps start with bleeding the brakes properly to see whether you have air in there somewhere. It is another question where the air would originate from.
guy (06-22-2024)
I know nothing of your vehicle or your location in the world.
It is normal for the brake boost to “charge up”. Its after affects that would worry me.
You mention “not notably decreased”. What does this mean? It should not decrease at all.
As @kajtzu suggests, many overlook the importance of brake system maintenance.
Cheers
Cheers
Cheers
Cheers
So I went through and checked for any leaks along the flexible brake lines, none to see.
https://imgur.com/a/GzZfgo0
I did notice that the line going into the booster has some wiggle with minimal effort. Does this seem normal to you guys? I'm kind of leaning towards something on the vacuum side since the fluid level has stayed the same with no signs of fluid leakage. I tried to trace the vacuum line to look for any obvious holes or leaks but couldn't see/ hear anything. Any recommendations to do a better job at detecting a vacuum leak?
