Radio, video, gps, phone and reverse parking camera not working
Pretty much the whole of everything on the screen is not working. Gps sits and freezes and "navigation is initialising", phone can't be paired, reverse camera works sometimes but normally it dosn't and the whole "Audio/video" section can't be accessed and it's blanked out: http://postimg.org/image/o1kj8d7ib/full/
All this started while driving through a storm. Through the hardest part of the storm everything was fin but after it had died out and was just drizzling the radio made a high pitch sound and everything stopped working How can I fix this? |
Lightning or water? I suspect it needs to go into the shop. If water it may dry out but and start working again but I wouldn't trust it. If lightning then something could be fried. What year is it?
This may be base for an insurance claim as water damage. I'm an lic Insurance Broker, so if the dealership cant/or refuses, file a claim on your auto if the resulting damage is truly from water.
Nothing works. Radio, NAV, Back up camera
Originally Posted by ktatlow
(Post 440617)
All this started while driving through a storm. Through the hardest part of the storm everything was fin but after it had died out and was just drizzling the radio made a high pitch sound and everything stopped working How can I fix this? Any answer to this problem? I have the exact same problem. No lighting over here Just sat in the garage for 9 days while I was on vacation and when I got home. Nothing works. Radio, NAV, Back up camera. Try currently doing a hard reset on the battery. Please help if you have the answer. Thanks |
Assume you've tried charging the battery and checking it? Alternator working under load, relevant fuses, etc.
I had the same issue a few years ago. I found an indy shop that repairs infotainment units on all makes. Brought the truck in for a day for them to diagnose and figure out which module was the problem, they determined it was the head unit and gave me a quote for $700ish to repair. After several attempts and trips back to them they were unable to repair it and installed a reconditioned unit for the original price. I haven't had any issues since.
Originally Posted by CaliLee
(Post 753490)
Thank you. That is invaluable info as there is practically nothing on this anywhere but a few sporadic threads about the problem and not the fix. I was already looking at head units. Refurb for about $290. Odd the way it went down without any real event. Thankfully the its an easy replacement I can do in the garage. Again thank you very much. |
Glad to help. I had a couple of incidents where the radio stopped outputting audio in the weeks prior to it going completely crazy on me but nothing else. Just started it one morning and nothing worked, tried pulling the battery connections and that didn't help. The online search began...
I'm in the south SF Bay area and used a shop called Short Circuit. |
(Post 753535)
I'm in the south SF Bay area and used a shop called Short Circuit. So I went through all the functions and secret menu ( accessed by holding the valet key for 40n seconds) on my unit, check all applicable fuses including those other affected functions. Then did a soft and hard reset per Land Rover Hawaii suggestions ( Positive and negative from the car connected) left it all night just to make sure,. I read there may be a battery in the unit itself that if a reset worked would need to be bled. Nothing. So it was welcome to get your input. Unit ordered. |
Radio navagation reverse camera not working.
(Post 753490)
