Transfer case shift motor replacement help (Calibration?)
Hello,
If anyone has replaced the shift motor, would you kindly advise if there is a DIY calibration procedure? Also, is there a trick or a convenient tool to get to the top bolt. Thank You so much, Igor |
You can unbolt the t case from the crossmember(support with a jack) and lower to allow access to the bolt.
You will need a diagnostic tool to calibrate |
