Transfer case shift motor replacement help (Calibration?)
Old Apr 13, 2018 | 08:21 PM
ebforce's Avatar
4th Gear
Default Transfer case shift motor replacement help (Calibration?)
Hello,
If anyone has replaced the shift motor, would you kindly advise if there is a DIY calibration procedure? Also, is there a trick or a convenient tool to get to the top bolt.
Thank You so much, Igor
Old Apr 15, 2018 | 08:52 PM
abran's Avatar
You can unbolt the t case from the crossmember(support with a jack) and lower to allow access to the bolt.
You will need a diagnostic tool to calibrate
philwarner
Mar 15, 2015 08:22 PM
martin12
Dec 21, 2014 04:49 PM
ColeRover
Feb 9, 2011 07:05 AM
discoandaboat
Oct 4, 2008 07:57 AM
thoward
Jun 3, 2008 06:01 PM
