Left over parts after trade in (LR4, Discovery, SCV6)
Miscellaneous
  • Miscellaneous - Left over parts after trade in (LR4, Discovery, SCV6) - New - 2014 to 2016 Land Rover LR4 - 2017 to 2020 Land Rover Discovery - Clarksville, TN 37040, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    $500
    • OBO
  • Location Clarksville, TN, 37040, USA
  • Condition New
  • Compatibility
Make Model Year
Land Rover LR4 2014 - 2016
Land Rover Discovery 2017 - 2020
$500 shipped for all. $450 for local pickup and you take anything else that you want (not listed) I prefer PayPal.
NEW OEM LR109354 Passenger-side valve cover. SCV6. Comes with valve cover gasket, all bolts (-2 for some reason), and mega black RTV sealant. ($120 shipped)
NEW Exhaust manifold gasket replacement kit (will break up if someone is interested): LR052347 and LR052348 left and right exhaust manifold gaskets, QYG500100 and QYG500110 upper and lower steering shaft bolts, 12 x LR034008 exhaust manifold bolts, 4 x LR010805 exhaust manifold bolt spacers (in case you lose any spacers while doing the repair), and WCM500110 catalytic converter gasket (only one on the vehicle) ($150 shipped)
NEW Corteco Motor mounts. If you are doing the exhaust manifold gaskets, you may as well replace these while you are in there ($90 shipped)
4 x used fuel injectors. 2/6 replaced to fix my misfire. I replaced the other 4 as preventative maintenance. ~65,000 miles. ($30 ea shipped)
NEW OEM front crossover pipe kit (Brand New): LR090630, LR092992, LR011038 ($90 shipped)
NEWISH 6 x Delphi ignition coils. Installed as part of my misfire diagnosis. My truck did not like them. Yours might. I replaced with OEM ignition coils. ($150 for all 6 shipped)
3 x used OEM coils. My misfire was caused by two faulty fuel injectors. These are still good as a backup set. ~65,000 miles ($60 for all 3 shipped)
