Rear Drive Shaft Conversion Kit For Land Rover Discovery I, Discovery Series II
Drivetrain
  • Drivetrain - Rear Drive Shaft Conversion Kit For Land Rover Discovery I, Discovery Series II - Used - 2001 to 2004 Land Rover Discovery - Philadelphia, PA 19122, United States
    Expired
    $210
  • Location Philadelphia, PA, 19122, USA
  • Condition Used
  • Compatibility
Make Model Year
Land Rover Discovery 2001 - 2004
This Land Rover drive shaft conversion kit makes drive shaft replacement quick and easy.
Land Rover Discovery I, 1994 – 1999 and Discovery Series II, 1999 – 2002 models feature angled drive shafts that use a rubber flex coupling, which wears down and causes annoying vibrations in your drive train. Our drive shaft conversion kit eliminates the need for a rubber flex coupling by providing a new drive shaft with a standard U-joint, as well as the flange, bolts, seal, spacer and dust shield – everything you need for the job in one convenient cost-saving package!
Also fits 1995 Range Rover Classic vehicles with short wheel base.
Like new condition, 25 miles on the setup. Decided to stick with the stock setup.
$210 shipped in the US.
Venmo, paypal, or cash app accepted.
Pickup also available in the Philadelphia, PA area.
