1990 Land Rover Defender 110 UK Spec RHD
1990 Land Rover Range Rover
  • 1990 Land Rover Range Rover - 1990 Land Rover Defender 110 UK Spec RHD - Used - VIN SALLDHMB7FA440603 - 4 cyl - 4WD - Manual - Wagon - Blue - Fair Haven, NJ 07704, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
3rd Gear
    $32,500
    • OBO
  • Location Fair Haven, NJ, 07704, USA
  • Condition Used
  • VIN SALLDHMB7FA440603
  • Engine 4 cyl
  • Drive Type 4WD
  • Transmission Manual
  • Vehicle Type Wagon
  • Exterior Color Blue
1990 Land Rover Defender 110 County Estate. UK spec right hand drive. 144k original miles on chassis. 2.5 litre J19 Turbo Diesel engine w/ 110k miles. LT77 5 speed manual gearbox.
Just brought over from Britain by its owner. Originally from Southport. A small town along the Irish Sea North of Liverpool. Then purchased by a business for commercial use in Nottingham and finally by its current owner, who resided in Chesterfield, southeast of Manchester, prior to relocating to The U.S.
Second owner swapped the original 19J motor for the later model 200TDi. The 19J was re-installed to comply with US importation regulations. OE motor has 110k miles with timing/cam belt service completed 5k miles ago.
Extensive service records dating back to the early 90's. Passed recent MOT prior to departing the UK.
Significant restorative cosmetic and mechanical work completed before arrival.
Including:
-Undercarriage corrosion mitigation and undercoating
-Complete respray
-New window seals including Alpine roof glass
-Oil/Filter Service
-Oil Pressure Switch
-Glow plug
-Starter
-Alternator
-LR Mud Flaps
-Fan belt
-Heater Hose
-Brakes
-Fuel Pump
-Headlamp/Rear Foglamp Kit
-Billet Gearshift and Transfer Case *****
-New Chequer Plate on body
Pioneer Single Din in Dash Stereo w/Headliner Mounted Speakers. Functional CB Radio.
Rear section can be easily re-fitted to original spec sliding plexi inserts as well as rear jump seats.
Located on the New Jersey Shore an hour south of NYC.
$32,500/offer
Thanks.
Old Jul 25, 2022 | 03:17 PM
ashtralia's Avatar
3rd Gear
Default Is this 110 still available?
Hello
interested in you 110 - is it still available?
Ashley
Old Jul 25, 2022 | 03:24 PM
Canyonrunner67's Avatar
3rd Gear
Yes It is at the moment..
