New defender rear storage
For SaleMiscellaneous
This is an underfloor storage system I made myself (not a professional). It replaces the under floor foam block and adds a large storage hatch and a base platform that can support an auxiliary battery, air compressor, etc. This will only fit the P300 110. Has an aircraft rail that was used to tie down a fridge. There is also a piece of ABS plastic where the fridge sites to protect the carpet. Both could be removed. Mounting hardware is included. The base plate mounts with rubber isolators to prevent any vibrations. None of the electronics are available. They have already been moved to another vehicle.
Free to a good home. Pickup only.
