2002 Disco II SD for sale
2002 Land Rover Discovery
  • 2002 Land Rover Discovery - 2002 Disco II SD for sale - Used - VIN SALTL15472A739040 - 106,000 Miles - 8 cyl - 4WD - Automatic - SUV - Blue - San Luis Obispo, CA 93401, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $9,500
  • Location San Luis Obispo, CA, 93401, USA
  • Condition Used
  • VIN SALTL15472A739040
  • Mileage 106,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Blue
2002 Disco II SD for sale.
Current mileage as of today is listed above, but we drive this around town every couple days for groceries, errands, etc.... I'll try to remember to update regularly.
Accessories
  • A Nanocom with unlock code for the Bosch engine
Here's what I have already replaced:
  • Coolant hoses
  • Serpentine belt
  • Solid lug nuts from LA wheel -- no more deforming stainless caps!
  • Replaced the windshield washer arms with Disco I arms (so they can accept off the shelf wiper blades
Here's stuff I need/want to fix and already have the parts for (will be included in sale):
  • A new shuttle valve switch -- to permantly fix the 3 Amigos (which aren't throwing codes when they light up for some reason)
  • New windshield washer pump motors -- need to be replaced, but not a priority for me since I fortunately never need to use them where I live
And here are the problems for which I need to buy parts:
  • Front passenger window stopped working a few months ago, I think it's getting power, I want to verify that when I have some free time so that I don't over-order unnecessary parts
  • Passenger side vanity mirror is hanging by one screw, probably an easy fix, but not something I really ever bothered to look into repairing
  • The plastic coating on the rear ladder is coming off, not sure that's repairable
  • It's got an aftermarket single DIN head unit that looks kind of annoying. I've meant to replace it with something with a floating display that supports carplay/android auto, radio works fine though
  • The coin tray and ashtray don't open. These are the lowest priority for me
Parts:
AB stainless brake hoses for a 2" lift -- the truck's not currently lifted, but adding one was part of my longer term plan for it
Current problems:
As I mentioned, the passenger window. I've also been seeing a slow coolant leak. I've had to top it off every month or two. I did a block test, and it was negative for any exhaust gases.
Cold start video:
