Fuel Injector Flor Test / Cleaning / Rebuilding Service
For SaleEngine - Intake/Fuel
As the title says, I want to offer Injector Cleaning and Flow Testing to the forum members. I can do all top feed injectors .
I can perform injector leak down tests, spray pattern analysis, static and dynamic flow testing (can monitor injector flow across an RPM sweep). I will also ohm test all injectors and provide a before and after data sheet including flow test results.
The service is $10/injector.
I can also replace the O-rings, filter baskets and pintle caps for an additional $10/injector.
I am located in North Carolina and can turn a set of injectors around in 3 days or less. If injectors need rebuilt, this might add a couple of days depending on replacement parts availability.
In addition to the injector service fee, you would also be responsible for shipping both ways, please make sure to include a return shipping label when you send me your injectors.
I will accept paypal or venmo.
Let me know if you have any questions.
Lou
