Aftermarket wheels
Old Apr 6, 2008 | 01:55 AM
rch1944's Avatar
Default Aftermarket wheels
I just purchased a 2008 Range Rover Supercharged with 20" wheels. I have ordered some Redbourne Duke 22" wheels. Now I am a little concerned that this change will have negative side effects, ranging from vibration to some form of driving difficulty. What can I expect?
Old Apr 6, 2008 | 08:47 AM
Default RE: Aftermarket wheels
Even your 20" wheels/tires ride bas, 22"s will just make it worse and the cost per mile on that size tire is off the charts.
Old May 3, 2008 | 10:09 PM
kkisting's Avatar
4th Gear
Just make sure they balance the wheels correctly. There might be a little shaking on the wheels but if it's too extreme they may have not put the weights on correctly... I just put on some 22" asanti's and it shook at first, but once they balanced everything it's pretty smooth. If you hit 60 mph you might feel a little wheel "vibration" but it's completely normal.
Old May 4, 2008 | 06:51 PM
LAWDOG's Avatar
I have heard that redbourne's have a centered hub, meaning they are very well balanced, Im get a set my self.
Old May 13, 2008 | 01:32 PM
RoverSC's Avatar
6th Gear
i added 22" TIS 07 wheels wrapped with yokohama prada spec x tires (285/35/22). personally think it rides and drives awesome. add nitrogen instead of regular air... increase the PSI a few lbs over recommended, check balance and ail. and you should be awesome!
cheers-
[IMG]local://upfiles/10371/FDD14C67E1FC415CB2D61DE6E1FFB79C.jpg[/IMG]
DiscoSux
Jan 8, 2011 01:10 PM
DiscoSux
Nov 10, 2010 10:19 PM
Fump
Aug 3, 2010 12:17 AM
onbelayclimbing
LR2
14
Nov 24, 2009 10:47 AM
LongDuckDong
Nov 6, 2007 09:38 PM
