-   Modifications (https://landroverforums.com/forum/modifications-33/)
-   -   build your own rock sliders (https://landroverforums.com/forum/modifications-33/build-your-own-rock-sliders-59045/)
TOM R May 12, 2013 09:06 PM
ok I saw a thread and cannot find it now had drawings to build your own sliders or have them built, anyone know?
CUpgt May 12, 2013 11:49 PM
3 Attachment(s)
I think DiscoMike has drawings. A buddy of mine that builds buggies built mine. Nothing fancy but stout.
Attachment 40816
Attachment 40817
Attachment 40818
TOM R May 13, 2013 08:35 AM
those look fine I would just need to weld on some step tubes, love the running boards but they keep getting hung up on stuff
where the long supports bolt to the frame are you using pre existing holes or are they new drilled?
CUpgt May 13, 2013 08:51 AM
New drilled holes. I will be adding tree bars/steps soon
Disco Mike May 13, 2013 09:15 AM
If you want some drawings, send me your e-mail address and I'll send them to you.
TOM R May 13, 2013 10:05 AM
pm sent thanks :)
any drawings for diff guards?
earlyrover Jul 15, 2013 01:46 PM
CUpgt
Those look good, but since they run such a long distance to the frame, where I assume they are bolted, one would think that they would bend upward a bit, if slid on big boulders? Many years ago, I ran running boards, but found them to hang up on rocks when creeping around narrow jeep trails in Montana mountains, so I never did like running boards when in the mountains on narrow trails.
drowssap Jul 16, 2013 08:00 AM
I believe the angle iron welded to the inside is to bolt to the rocker panel;
Disco Mike Jul 17, 2013 08:47 AM
1 Attachment(s)
It only takes 3 or 4" grade 8 bolts to secure the slider to the body, look at the picture below.
They do not need to be attached to the frame, those long arms just give you more things to get hung up on in the rocks.
Madlands Jul 17, 2013 03:39 PM
Mike, I may be weong because Im on my phone but, that pic you put up looks like its in CAD or some sort of solidworks. Does that mean you happen to have the measurements and stuff for those pictured? If so I'd sure appreciate them.
