build your own rock sliders
Old May 12, 2013 | 09:06 PM
TOM R's Avatar
Default build your own rock sliders
ok I saw a thread and cannot find it now had drawings to build your own sliders or have them built, anyone know?
Old May 12, 2013 | 11:49 PM
CUpgt's Avatar
I think DiscoMike has drawings. A buddy of mine that builds buggies built mine. Nothing fancy but stout.
Old May 13, 2013 | 08:35 AM
TOM R's Avatar
those look fine I would just need to weld on some step tubes, love the running boards but they keep getting hung up on stuff
where the long supports bolt to the frame are you using pre existing holes or are they new drilled?
Old May 13, 2013 | 08:51 AM
CUpgt's Avatar
New drilled holes. I will be adding tree bars/steps soon
Old May 13, 2013 | 09:15 AM
If you want some drawings, send me your e-mail address and I'll send them to you.
Old May 13, 2013 | 10:05 AM
TOM R's Avatar
pm sent thanks
any drawings for diff guards?
Old Jul 15, 2013 | 01:46 PM
earlyrover's Avatar
CUpgt
Those look good, but since they run such a long distance to the frame, where I assume they are bolted, one would think that they would bend upward a bit, if slid on big boulders? Many years ago, I ran running boards, but found them to hang up on rocks when creeping around narrow jeep trails in Montana mountains, so I never did like running boards when in the mountains on narrow trails.
Old Jul 16, 2013 | 08:00 AM
drowssap's Avatar
I believe the angle iron welded to the inside is to bolt to the rocker panel;
Old Jul 17, 2013 | 08:47 AM
It only takes 3 or 4" grade 8 bolts to secure the slider to the body, look at the picture below.
They do not need to be attached to the frame, those long arms just give you more things to get hung up on in the rocks.
Old Jul 17, 2013 | 03:39 PM
Madlands's Avatar
Mike, I may be weong because Im on my phone but, that pic you put up looks like its in CAD or some sort of solidworks. Does that mean you happen to have the measurements and stuff for those pictured? If so I'd sure appreciate them.
