Decent shackle mounts
Old 12-13-2018, 08:15 AM
Fastercat's Avatar
Default Decent shackle mounts
well I just finished up my bumper with the exception of shackle mounts. I just wanted to get some opinions on what you guys think is the best way to go. There is weld on, bolt on, thick weld on, ect. I was even debating buying 2 hitch receiver shackle mounts and cutting them back and welding them on. More weld area for the 2x2” square. Cut down of course.
Old 12-13-2018, 08:17 AM
Fastercat's Avatar
Old 01-22-2019, 02:55 PM
Nigelw's Avatar
The first eye plate is best and should be fitted into the bumper through a slot cut into it and then welded from both sides.
I liked the eye on a bolt on plate but it then becomes quite a cumbersome lump on a sleek bumper, if it were me I would rather the weld in type with multiple pass stringers.
Old 01-22-2019, 06:45 PM
Received 1,589 Likes on 1,305 Posts
Old 01-22-2019, 08:06 PM
mrbieler's Avatar
5th Gear
I have JATE rings up front and a hitch shackle in the rear. Never had an issue using either.
Richard Gallant (01-24-2019)
Old 01-22-2019, 08:14 PM
Jate rings are great if you are running a stock front bumper
Old 01-22-2019, 08:59 PM
Fastercat's Avatar
Welded them up
They were built to bolt in but I didn’t think it would look good
So I cut out openings and slid them in from behind
My friend made these up for me out of 1&3/4 solid stock with a 1/2” plate
Finished after touch up paint. I even got a neoprene cover for the winch
Old 01-22-2019, 09:29 PM
stillruns's Avatar
Nice job!
Old 01-22-2019, 09:45 PM
Nice work
Old 01-23-2019, 12:39 PM
Nigelw's Avatar
I run these on the LR3 and love them
https://www.lucky8llc.com/products/t...recovery-point
What thickness plate have you mounted them in?
Quick Reply: Decent shackle mounts
