OME lift
Old May 21, 2007 | 05:27 PM
Default RE: OME lift
The test book they use cost the dealer ship $33,000 give or take a little, hell some one has to help them pay for it.
Mike
Old May 21, 2007 | 05:31 PM
bigugly82's Avatar
llesra,
Where did you find those instrunctions? I'm going to be swapping the susp in my '03 Disco and think I want to do it myself. Or are the instucts about the same?
thanks
Old May 21, 2007 | 06:24 PM
JavaRacer's Avatar
ORIGINAL: Disco Mike
Mike
WOW!!! That's one hell of a pricetag! Haha! I guess I don't feel so bad payin' up, then.
Old May 21, 2007 | 08:51 PM
llesra's Avatar
ORIGINAL: bigugly82
llesra,
thanks
http://www.discoweb.org/slstocoils/index.htm
i got the instructions from discoweb. it says the instructions will work for all years of the DII with the sls.
Old May 22, 2007 | 08:51 PM
JavaRacer's Avatar
1. No lift with running boards.
2. No lift without running boards.
3.After lift.
4. After lift.
Old May 22, 2007 | 09:03 PM
JavaRacer's Avatar
These 3 pics are all from about the same angle and in the same location. The first 2 are before the lift, one with running boards and one without. The rear air suspension was lifted so I could get underneath to remove the running boards. Sorry, I don't have a pic with the rear deflated from the same angle. The 3rd pic is obviously after the lift.
[IMG]local://upfiles/6049/37B92D47164A4573A206DA727766C007.jpg[/IMG]
[IMG]local://upfiles/6049/ACBE7ABC798D4E2F85C949F3FCF7CA03.jpg[/IMG]
[IMG]local://upfiles/6049/AC547B9B40CF4966BA44FCC9E77DEBE2.jpg[/IMG]
Old May 22, 2007 | 09:09 PM
JavaRacer's Avatar
Here's one more try. Okay, it didn't work but now it does. Fixed! The pic by the old church is without the lift.
Old May 23, 2007 | 04:31 AM
bamarover's Avatar
those last two downloads did work.
Old Jun 18, 2007 | 11:24 PM
N.Franklin's Avatar
What rate did you go with on the OME springs and shocks, are they the medium or heavy rate?
Old Jun 19, 2007 | 11:02 AM
With OME you must always run their HD shocks, the standard shocks are too soft. As for the coils, most people lean towards the HD side for a better, more controlled ride especially if you plan to go off road or want to keep the body roll to a minimum.
Shout if you want some help or a good site to buy your OME's from.
Mike
