Roll Cage
Find a guy that do metal works. I think he can make you one. Or you can buy a welder and start doing it yourself.
________________
If you ain't first your last!
Ring and Pinion Set
________________
Ring and Pinion Set
Roll Cage
How have people done the dash and supports on a r32 when fitting a roll cage.I am welding in a basic kit main hoop, a pillars screen bar and then adding in all the door, roof bars, rear stays diagonals etcHave you taken out the stock dash bar?" " " the heater matrix? or have you made the cage fit around it.Any info or pics would be greatly appreciated
