roof rack flooring covering?
Old Jan 17, 2014 | 06:20 PM
dusty1's Avatar
Originally Posted by TOM R
2 things
1) that 3 m tape sucks I used that on my in laws handicap ramp and is nfg we're, you also need to use contact cement for wood surfaces still been like 6 months and they are peeling followed all directions to the letter, only good when dry
2) that carpet runner vynil also sucks when wet, you will turn the roof into a slip n slide
You could use paint then throw sand on it used it on a trailer worked OK cheap
thanks. I kind of suspected that with the 3m but good to know on the vinyl.
any experience with that no slip epoxy garage floor paint? probably the same results could be had with the medium thrown in the paint, I'm guessing.
Old Jan 17, 2014 | 07:05 PM
fishEH's Avatar
Yeah, why not some bedliner??
Old Jan 17, 2014 | 08:17 PM
dusty1's Avatar
now thats an idea. provided grip, right? edit= searched and yep that is what it says....slip resistant.
on it....hope I can find pink
thank you very much
Old Jan 18, 2014 | 04:59 AM
antichrist's Avatar
Or paint and a packet of the grit Home Depot and others sell for adding to paint to make it slip resistant.
Old Jan 18, 2014 | 07:06 PM
Copper99's Avatar
6th Gear
http://www.nonslipcoating.com/
This stuff is supposed to really good
kinda pricey at $119 a gallon
Old Jan 21, 2014 | 10:52 AM
drowssap's Avatar
i think you had the right idea with the Home Depot rustolium garage floor paint, it will have no problem stick to the plywood and once you throw the speckle stuff down, it becomes slip resistance.
Old Jan 21, 2014 | 11:21 AM
dusty1's Avatar
yep...well, i was set on bedliner, but reviews say no go on plywood. so i have 2 gallons of that homy d garage stuff in my trunk. I will slop it on today
Camdisco24
Jul 27, 2010 07:59 AM
rj95lss
Mar 17, 2010 10:17 AM
JohnLRDisco04
Jul 28, 2007 01:06 AM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
