Will 95 parts fit 97 Disco
Depends on what you are looking to do with it.
95% of the parts will fit, just not the engine or computers.
Rims, glass, body panels, interior...it all fits.
Except the front seats, only power seats will switch over, if the '95 has manual seats they wont bolt right in.
You will need to modify them.
What about the fuel pump, water pump? Is there a site I can check to compare parts for fit? I'm not wanting to replace the engine just some bits. I understand not everything will fit. I just want to know if buying the "junked" 95 is going to be worth the time and effort. There is nothing wrong with the 95 really just a busted out window and needs a new paint job and maybe a few other cosmetic things.
Fuel pump yes and no. The actual pump appears to be the same. If the 97 has AEL the 95 assembly won't work. Well, it will, but you'll have a constant CEL.
No specific sites for a part by part comparison, but you can check RN or AB, look up the part you're wondering about and see if it lists two different ones for 95 and 95.
roverintherocks
12-08-2010 10:36 AM
range roverrr
09-11-2009 10:25 PM
