2017 TDV6 ZF8 Transmission Fluid Change
I finally got to do the fluid change.
https://cimg3.ibsrv.net/gimg/landrov...f2f1fcb16a.jpg Level rig up. Ramps or jack stands. https://cimg3.ibsrv.net/gimg/landrov...492ffdd407.jpg Kit from FCP Euro. They shorted me 1 liter, didn't need but 5 anyway. https://cimg5.ibsrv.net/gimg/landrov...f40bd52dc0.jpg belly pan has 8 15mm bolts. I also loosened the 4 front belly pan bolts, because this pan slide under the front pan. https://cimg9.ibsrv.net/gimg/landrov...f95b5458c0.jpg Belly pan removed, looks like original tranny pan. https://cimg6.ibsrv.net/gimg/landrov...4cdf2a9e40.jpg 8mm hex drain plug, passenger side. https://cimg3.ibsrv.net/gimg/landrov...eddfd45ec5.jpg Pan removed, and cleaned and ready for new one. https://cimg0.ibsrv.net/gimg/landrov...c895f40cef.jpg New pan installed. 8Nm torque, I'll post the torque pattern. https://cimg8.ibsrv.net/gimg/landrov...a79a77f5ad.jpg Magnet in old pan https://cimg4.ibsrv.net/gimg/landrov...f58a1354b1.jpg Magnet in old pan https://cimg5.ibsrv.net/gimg/landrov...a55eac6b39.jpg old pan Full instruction here. https://www.fcpeuro.com/blog/how-to-...d-transmission My notes: I filled until drizzled out. Started truck, held brake, went through gears, R-N-D-S, it would only allow S1, S2, S3...........waited till temp reached 45C With truck still running, pulled fill plug, finish topping it off. shut it down, checked for leaks, performed reset: 0. Press "Start" button only. (ie: Do NOT start the engine.) 1. Press and hold gas pedal to floor for approx. 15secs. 2. Press "Start" button again. 3. Release gas pedal. 4. Wait approx. 2mins.; start engine and drive. She is smooth as Butter! |
well done, and thank you as always for sharing your expertise! :cheers:
You can only drain what drains and there will always be residual of the old fluid, correct? Looks so easy via pictures! (Famous last words.....). Thank you for sharing.
Originally Posted by gmfain
(Post 897266)
https://cimg3.ibsrv.net/gimg/landrov...f2f1fcb16a.jpg Level rig up. Ramps or jack stands. Full instruction here. https://www.fcpeuro.com/blog/how-to-...d-transmission My notes: I filled until drizzled out. Started truck, held brake, went through gears, R-N-D-S, it would only allow S1, S2, S3...........waited till temp reached 45C With truck still running, pulled fill plug, finish topping it off. shut it down, checked for leaks, performed reset: 0. Press "Start" button only. (ie: Do NOT start the engine.) 1. Press and hold gas pedal to floor for approx. 15secs. 2. Press "Start" button again. 3. Release gas pedal. 4. Wait approx. 2mins.; start engine and drive. She is smooth as Butter! |
Originally Posted by bkjecu94
(Post 897310)
Originally Posted by ar077
(Post 897338)
I notice that you have Lucky8 rock sliders (as do I). The rock sliders can support the vehicle and I use my Hi-Lift jack with an adapter ( https://www.amazon.com/dp/B00F4HX9FW...language=en_US) to lift either side of the vehicle. I'm thinking that jack stands positioned at the four corners of the rock sliders could support the vehicle with the wheels off the ground, which would facilitate cycling through the gears without having to apply the brakes after changing transmission fluid. Comments?
I thought about the four jack stands also. I was just not brave enough to try it. If you try that method, let us know how it goes. |
Are those reset steps just for the transmission or for the service light?
Originally Posted by 1979rover
(Post 897588)
Nice thanks for sharing I need to do mine soon!
